replacing arches
has anyone had there arches replaced? iam looking at replacing my rear arches on my 6n, i can get hold of them easily, just wondering what sort of price it would be to get them welded an painted up?
cheers guys
  • Views 1k
i had mine pulled and built up not replaced you also need to do work on the rear bumper to make it follow the lines into the bumper :)
i assume you want to fit wider wheels ?
there rusting, had them resprayed once and its creaping back, want to get them replaced so they dont keep rusting, found a website site that have primed up arches at £25 pounds each. just want the old ones cut out and new ones welded in. cheers
you can't weld in primed arches ?
it all depends how bad the rust is but if someone has done a poor repair and it's come back then usually you need more work than if it was done correct the first time, it's definately not something you want to be doing yourself leave it to the profesionals, i'd probaby let them get there own parts too as they know what they trust ;)
I agree that if they've been sorted before they should be fine, replacing them wouldn't necessarily stop the rust coming back. I'd see if you could get someone else to take a look at them and give you a quote?
