Bonded Windows
Does any one know how easy it is to fit a side window in a polo ? Its a bonded one and have a tube of window sealant and the glass, just want some help/Advice b4 i try it ! I aint payin what the local companys want to fit it £25 upwards !
id pay the £25 atleast its guaranteed then. but if u want a go, you will have to get all the old ish of the car, clean it up good so the new stuff gets a good surface to bond to, also make sure the window is clean. is the window sealant you have the proper black stuff?
and if its sikaflex you are using heat it up in a bucket of warm water! its rock solid when using it cold with a normal hand squeeze gun!!
Clean the area with thinners, also don't leave any breaks in your glue, sounds obvious but if not touching the surface when putting it on it can leave an area that doesn't bond and leaves you with a leaky window :(
the edges of the glass will also need a special primer, personally £25 is nothing it'll cost you that for the stuff to do it yourself
Sadly it's not as easy as just sticking them on with some sealant, yes it'll look right for a while, but it won't be right. Better to pay to have it fitted.
