What is this shit?
Seen this on loads of dubs of the same era. I presume its whatever the reg plate is stuck on with.
I foolishly tried to t-cut it off and went almost through the paint (pink area). What's best to get it off anybody?
  • Replies 12
  • Views 2k
looks like the glue out of your number plate. get a new one :D
Will that help? :-D
looking at the state of the plate, you can see where the backing has seperated from the plastic, and the glue has run out of it. a new plate should stop it. i take it there isnt any above the plate?
Well no, but the problem is getting it off the paintwork fella. It's like fuckin rock. I need to know what will disolve it but not the paint. Any idea?
i got a pot of this from halfords, real good stuff, great at getting tar off my car and i had cooking oil poured over it, done a great job
autoglym tar and glue remover
meguires bug and tar removed it mate or meguires paint renovator. or if its kinda sticky maybe abit or wd on a rag or petrol and a wash after?
WD is great aswell for cleaning alloys :D
As a last resort try using Evostick contact adhesive remover solvent. Bare in mind it will remove cellulose paint if thats been used on the car. Try it on an inner panel 1st before trying to use on the glue shit. Very carefully use a plastic scraper(like the spatula one you get to apply car filler) if it is very stubborn.
It's all about getting the right solvent to soften the glue so go very careful and don't go blaming me if you bugger the paint. Good luck
Edited by MacColl
id sort your number plates sorted out first or its just gonna keep coming back
how d'you gerrum orf then? Good tug take care of it?
Try a caramel wheel. Its designed to take shit off but without damaging the paint or having to work until the muscle in your arm explodes.
Have you ever used one? Does it really leave the paint alone?
