thinking of spraying standard valver wheels.
hi i was thinking of spraying my standard valver wheels.
I've found acouple of guides which i will be following as I've never done anything like this before but hopefully all will go well.
i was just woundering what make of paint/lacquer would you recomend.
and also what colour do u guys recon i should spray them i was thinking either black or white and i got a pic to give idea.
but then part of me wants a colour that noone else will have like red or glow in the dark green(if they do it).
anyway what you guys think and any advice about this as i will ahve to refurb as I've curbed one abit would be great.
Edited by shitheady2k
  • Views 1.3k
Do'em black!
do them black with a white spiral, really freak out when on the move :D i like both, i prefere white on that blue. as for the paint, halfords stuff will do, or a motor factors will prob be cheaper. clear laquer is a good idea to give it as much protection as possible from the dreaded salt!!
i would say do them black if anything! keeps the car looking stealthy and makes it appear lower as well whereas white gives it more of a rally look and makes it look higher unless your tucking rims of course?
Before you start clean wheels with fairy liquid to remove contaminants then wipe over with white spirit or thinners
Halfords do a metal filler which u kneed together in your hand then leave to set for 24 hrs ideally then sand back as normal filler
Use 240 grit dry and key the wheels so they are all matt look with no shiny patches on them and that they are smooth (if needed apply filler and sand)
A couple of coats of primer and then normal car paint and laquer is fine, altho if I'm painting wheels black quickly i tend to use hammerite spray cans as it drys super tough and gives a nice finish, otherwise spray gun and booth
any good?
I've brought the stuff now just got halfords make primer/paint and lacquer and some sand papaer and a block all for less than £30 thought id get the 500ml cans.
I've gone with the black idea but I've got an idea :unibrow:
i think I'm going get a small can of blue paint same colour as my car
make a stencle of the vw badge and spray it on the blot bit in the middle.
opefully will look good when I'm finshed and I've got a long weekend do it :).
wish me luck.
sorry I'm struggling to upload these imags its saying they are too big so I've tried putting them in gif format.
pic?
