6N 8Valve Gearboxes
hi guys, it seems my gearbox is spannered in my 1600 AEE mk4.
obviously i want to now find a replacement, can anyone tell me, do all the 8valve engines use the same gearbox?
failing that has anyone got a list of all the gearbox codes?
cheers.
  • Views 908
all the engines have a different gearbox i believe.
even the 1.4 8v can have two different gearboxes as they have different selector linkage.
All the same apart from diff ratio's matey
  • 8 years later...
Help  So i have the same problem.
1997 polo classic 1.6 AEE engine with a DCK gearbox.   The gearbox is shot and i want to swap it.  I dont care about ratios just want to know what box i can buy that will fit and bolt straight up to the 1.6 8valve .
didnt want to start new topic and there is conflicting info above.. So any ideas guys???
thanks!
