handbrake lever mk3
managed to find a nice shiny handbrake sleeve that will fit my car whilst at work!!
What holds the original sleeve on? Is it a crosshead or flathead screw or some kind of star nut thing? Had a go with a flathead and a crosshead but neither seems to work (unless its me?)
Its in one of those places that you can't get down to have a look! Grrrrrrrrrr.
  • Views 856
look underneath the front of it (just back from the button) there is a tab which needs to be pressed in with a screwdriver (flathead) and then it should slide off. If not then hacksaw it all off and go from there :)
i found a hole at far end from button. thought there might be a screw in there? I'll just hacksaw the soddin thing off!
cheers buddy.
