Clarion DXZ958RMC
Clarion DXZ958RMC
Got this as it came with my Golf but put my own stereo in it so is no longer required.
Really nice headunit with all the bells and whistles, got this music catcher function on it with allows you to download music to the headunit.
Comes with headunit, fascia, all wires and fascia carry case. No remote or instructions.
Open to offers on this
£400 New
so
£180??
Specs from Clarion Website
DXZ958RMC main features:
Full colour 4.2" TFT screen with touch control of radio's functions on a stainless steel motorised front panel
Includes the high capacity version of Clarion's internal memory recording feature - Music Catcher to store nearly 6 hours of music
Includes AC Processor IV for Dolby ProLogic II surround sound and many other digital time alignment effects
Compatible with Clarion's extensive range of CeNET accessories - including CD & DVD changers, DAB tuners, TV tuners, iPod interfaces and Bluetooth handsfree phones
Powerful 4 x 53W amplifier with four channel preamplifier outputs for adding to your system
Connect your Walkman or PDA thought the stereo auxiliary input facility
Radio tuner features:
DSP digital signal processing radio tuner processes demodulation digitally to reduce adjacent and multipath interference for clear and noiseless reception
RDS (radio data system) & EON (extended other networks) tuner
TA traffic announce function will switch station for the duration of a traffic report. The original station is restored at the end of the report.
PTY-EON (programme type) information displays and allows selection of similar types of programme (news, pop, classics, sport etc.)
Full coverage of LW / MW / FM wavebands with 24 presets (18FM, 6MW, 6LW)
Distance (DX) and local (LO) seek tuning is possible
Auto-store entry feature stores best stations available in current location
Preset scan will play stored stations in sequence for a brief period
CD / MP3 / WMA features:
24 bit D/A converter for the utmost in sound clarity
CD-R and CD-R/W compatible
Display of CD text & ID-3 tag information
Compatible with multi-session CDs
Up to 254 tracks can be organised into max. of 128 folders
Random track play, track repeat and intro scan functions
Amplifier features:
Digital Crossover circuit separates the sound spectrum into different bands to allow peaking and phase cancellation to be minimised thus reducing the muddiness that can result with a 2 or 3 way speaker system
Digital Time Alignment virtually 'moves' speaker positioning to ensure listener appears to be positioned exactly in the middle of the sound field. Distance can be adjusted from 0 to 500cm in 2.3cm steps
Dolby ProLogic II decoder lets you enjoy 5.1 channel surround sound with any two channel source, including DVD, CD, MP3, WMA and radio. Virtual 5.1 channel sound using 4 speakers is also available
Virtual Space Enhancer lets you digitally correct irregular reflection, polarisation and other acoustic problems resulting from your vehicle's design. Simply choose from three available options: Sedan / Wagon / Mini-Van
Four channel 4 x 53W max power amplifier (4 x 25W RMS)
Internal amplifier can be turned off
Six channel preamplifier gold plated RCA outputs (4 volt) for connecting optional external amplifier
Stereo RCA auxiliary input for connecting Walkman type device
Separate adjustment for bass, treble, balance and fader
Low pass filter (Off / 50 / 80 / 120Hz) and high pass filter
Switchable subwoofer output turns rear channel preamp outputs into dedicated sub channel
Anti distortion filter (ADF) reinforces bass / treble sound to minimise phase distortion effects caused by compressed music sources
Three band parametric equaliser (independent control of front and rear channels)
MAGNA-BASS loudness feature
Speed dependent volume control feature (requires GALA speed pulse signal to radio)
Other features:
Stainless steel motorised front panel with 4.2 inch TFT touch control full colour display
Active MatriX control allows use of one-touch menus to simply control complex multimedia functions as well as other system components. Call up programs, select stations, input titles, control audio and video output - all with finger tip touch control
Music Catcher will record up to approx. 353 minutes (LP) or 265 minutes (High Quality) of CD music into radio's internal memory
45 second anti-shock memory temporarily caches playback data so if a bump in the road sends the laser off track, playback sound will not be affected
Control button illumination colour can be set to one of fifteen colours
Can be linked to many factory-fitted remote control systems (requires accessory interface)
Rotary volume controller
Auto display dimmer with sensor to adjust display according to vehicle's interior brightness
Display contrast adjustment
Display wallpaper or customisable screen saver can display your 30 character message
Display can be switched to show clock time
Clock time auto-set from RDS information
Auto muting when connected car phone rings or is in use
Bluetooth car phone audio can be played through radio (accessory adaptor required)
Up to 50 ten character titles can be entered for CD discs. (20 for TV mode, 100 for CD changer)
Complete with front panel carry case, Clarion ISO loom, release keys, installation guide and owner's manual
Security, warranty and insurance:
Removable front face with case and flashing LED indicator
  • Views 431
no disrespect mate
but my local car audio centre does these brand new for £100 now!
just thought it might help your sale, good unit these are!
no disrespect mate
can you prove that? As far as i'm aware the cheapest they retail at as 249.99
yer i cant find one around for that cheap!!!!!!!!
no disrespect mate
if they do then go and buy as many as you can to eBay cos there is nowhere selling them that cheap. are you sure you've got the right model?
yep definatly this model, think its actually £109.99
might go and buy a few then and get em on ebay!
