g40 engine and gear box wieght?
as above does anyone know how much a g40 engine and gearbox weigh,s ? will i be ok traveling with one in the back of a corsa or will i have to hire a little van? any one know
  • Replies 8
  • Views 1.5k
I've got a peugot 106 and drove from sheffield to surrey with a gt engine a spare wheel and 2 people in the front and it was fine apart from had to take it easy round corners
Box is circa 25-30 kg empty I think, and an engine I can carry reasonably easily, so must be under 100 kg-ish, and the charger and associated bits can't be that much, maybe another 30 kg for everything else. Call it 150-160 kg for everything - it should be fine in the Corsa with bits methodically laid out. At the end of the day it's just like carrying 2 passengers or 1 fat fuck.
:lol: yeah thats what I'm thinking lol
All together it's pretty darn heavy. It takes two to lift the complete engine (head + block) and then gear box is quite substantial too. We carted my engine 150miles in the back of a Mk3 Polo...scrubbed a bit on the tyres....but seemed ok! I found moving myself forward in the passenger seat helped even the weight distribution lol.
Edited by Tav
Yeah, no problem, just keep it as close to the front as you can so you're not overloading an axle (guaranteed pull if you go past a police car) and make sure it can't roll about.
The dripping oil and coolant isn't great for your interior though.
Where's it going to and from? Might be able to sort something out.
If your not taking a passenger stick the gearbox in the foot well to help bring some of the weight out from the back.
box is 33kg empty.
i had my g40 engine and gearbox in the back of my mk3 GT slammed 60mm all round and rear strut brace witch stopped the engine being sat in the centre of the car instead over the back end and travelled 150miles with no problems and still cruised at around 70 to 80 mph down the motorway!
