How to change indicator lights mk4?
Culdnt find anything :(
A step by step would be very helpful but i've had a quick look at my 6n indicator lights and they look fixed on there pretty tight. I know this is a cummon mod to change you are indicator lights to clear so would anyone help?
thanks!
  • Views 989
Its really easy, you just need a spanner.
1) Open up the bonnet
2)Loosen and remove the bolt holding the indicator inplace, then keep the bolt safe.
3)Slide the indicator out towards you if your standing infront of the car.
4)On the back of the indicator, the wires connect with a twist latch, like on the side repeaters...
5) Twist (anti?)clockwise to remove this, and the bulb will come out with it.
6) Twist bulb out, replace.
To lift a phrase from the haynes manual, Refitting is a reverse of removal ;)
Hope that helps.
Just read your post properly :lol: basically to change to clear indicators completley just replace the entire indicator when youve removed it, but you WILL need some silvatech bulbs that appear silver/clear but flash orange or youll get pulled fairly sharpish.
Edited by toddy89
