Respraying my G40, need some panels replacing
Hi all, I'm respraying the G40 soon and need 2 new wings. Now the guy who is spraying it said I should get genuine panels but a friend of mine said that any car older than 5 years is replaced with pattern panels when having insurance work.
Just wondering if anyone has used any pattern panels and how they found them? I can get pattern panels for about a third of the price so if theres not much difference I'll prob do this. However if people think I'll be better off gettin genuine panels, I'd prefer to spend the money on them.
Jake
  • Views 1.3k
I'd take the advice of the guy spraying the car. Any body shop I've been to strongly advise using the proper panels as the metal is often of much better quality. If you are going to do a job, do it right. It's only £60 a wing anyway.
Use originals. Pattern parts very rarely are exactly the same dimensions, so don't fit quite right!
fair enough, genuine it is then. Thing is I also have some rust comin through on the front upper panel. Had a price from VW for £100!
Anyone think its worth finding a good condition one off someone breakin a mk3?
the top section of the front panel seems a common place for rust on mk3's. you may find a decent second hand one if you're lucky. remember it needs the spot welds drilling out to remove it.
always use genuine parts..
stay clear of pattern
yeah also the panel behind the front bumper ( is it the slam panel?) has rust on too so I'll be replacing that aswell.
Where are the spot welds you were saying about?
