NZ Engine choice new
As new, did the NZ engine cost more than the 1.3 spi motor, and did the buyer have a choice? I know that a large number of genesis spec models had the mpi lump, but there are late spec models with it too.
Just wondered whether you got the option or not!
  • Replies 18
  • Views 2.8k
i don't think it would be an option, the spi and mpi 1.3 are both 55 bhp so there wouldnt be any need for an option.
apparently the nz's were used in mk2 golf's on the continent and were 'run-out' in mk3 polo's.
So it was just hit and miss?
from my experience i'd say it was.
my sisters 1.3 genesis was spi, the genesis 1.3 i had was mpi... it's weird!
Wouldn't say they were run out, IIRC, most earlier genesis 1.3s were NZ, and all the late ones are SPI.
what i meant by run-out was what you said toby, they just used them til they had no more of them :)
yes hit and miss. I think VW just used them up in early mk3 1.3s. Most mk3 saloon 1.3s are NZ too.
I would have thought the NZ would be a more desirable unit? As it made more power, though that wasn't the official story...
Once VW bolted the cat onto the NZ (didn't have one in the Mk2 Golf) it really wasn't much better than the SPI lump because they never bothered setting it up properly? At least, that's one of the stories I've heard :lol:
martinb - cool cool, I got the wrong end of the stick lol! happens a lot...
I've heard walshc enjoys suffers from that too
Edited by skatty_01
Walshy likes both ends :wink:
There's no mention of the NZ lump in the Mk3 brochures / owners manuals I've got, or the Haynes Manual for that matter, so might not have been official for this car..
Most early 1,3s in the 2F was NZ (like mine produced in 1990), but VW switched to AAV as it was cheaper to produce. At the end of the 2F's life they went back to the NZ as this had better emissions. There are a few differences betwen the early and late NZ's, like coils and TPS's
Edited by G40NUT
At launch, it was expected (or to use VW terms: 'planned') that the 'Digijet' or NZ unit would be replaced by Monomotronic in January '91.
Looking at ETOS however, it doesn't make things any clearer. AAV's are listed continually from 31/01/91 to 31/07/1994 (although there is a blip/ irregularity between June and August '92). NZs were listed from 31/10/90 to 31/12/92 with some gaps in the first few months of '91 and '92. Other than that, I’m not sure if there was any logic or pattern to when NZs were popped in the 'bay.
In all cases, the buyer was never given the option of whether they wanted Mpi or Spi. As far as the brochure post January '91 was concerned, you were going to get an Spi unless you went for a GT or G40. In hindsight, the buyer may not have received what the brochure suggested.
The later digijet ECU's were built later, as they have been different parts to replace components that have come obselete. They use different eproms but both have the same ecu code, except the later ones with the newer Eprom have the same code in twice!
It would be good to get a stock NZ and AAV RR just to see the difference. I sure the NZ will have a much better torque curve.
the 2 Polo that our Matt got his NZ bits from were both H reg........one was a CL coupe & the other was a squareback with a 4 speed box
NZ Coupes... That must be a rare thing? All the NZ I've seen have been breadvans or saloons.
i had an NZ coupe, in grey. was rock hard that thing i tell thee!
mine was an nz coupe... so much weaker than my Gt though, makes me cringe when people say they have near gt power as standard... get a gt cam, chip and gt gearbox on and they may have a valid point!
