Door mirror disassembly
I stupidly knocked my passenger door mirror on a tree while reversing (I had the mirror pointed towards the kerb). It caught the tip of the mirror and shattered the plastic indicator cover. Luckily I've managed to get a new bottom section including the LED indicator from VAGParts for about £15 -- highly recommend them.
Problem; how on earth do I disassemble the door mirror so that I can change the bottom section? The new part doesn't give away many clues, it's obvious that the bottom section pushes up and clips in somehow as there is a fixed moulded connector for the indicator.
Any ideas? I think the painted top section needs to come off but I don't want to force it in the wrong way and end up needing a whole new mirror.
[Edit]
It's a 2006 model.
Edited by JF1980
  • Views 807
Ok worked it out. For reference you need to release the clip halfway along on the front edge. A blade or slim/wide screwdriver will do it. Pop the top cover off and then undo the two torx screws.
Took me about 15 mins and cost £15-- better than buying a whole new mirror!
Edited by JF1980
