Breadvans....
Have got a mk2 breadvan which I use as a daily driver
It needs a bit of work doing to it to sort out the rust and have been thinking about an engine change as the carburettor on it is pants. What would you guys recommend?
Have been told that quite a few of the "old" guys on here have done engine changes on breadvans before!! :-) :-)
Please let me know what you think/suggest
Ta
  • Views 1k
Mk3 GT conversion... 0-60 probably be a shade under 10 secs in a Mk2... So nippy enough. Decent gear ratios and nice revving motor. Fit the EFI too, and you'll get 45 mpg.
Personally wouldn't recommend a G40 engine swap unless you need that sort of performance?
Failing that a short term fix would be to ditch your pierburg carb in favour of a weber.
Can agree strongly to both the above comments, a weber carb will give good running, and if the mounting plate is "opened out" you will get an improvement in performance. A GT conversion is much more work, but is very worthwhile.
weber tha bastard!
