whats needed to fit 8v fogs?
Hi there, I'm not 100% sure where this should go as its kind related to electrics and bodywork so i guessed here. :?
I've recently bought some 8v fogs with the understanding that i need to chop up my std lower bumper panel to get them to sit correct so before i go and do this i thought i would ask here where abouts they are suppposed to go and what else i will actually need to get them all set up and working correctly? :-)
All i have is the fixings and the actual fogs so things like switches/wireing kits anything like that i will be needing so if anyone has any or knows what the VAG part code is please it will be greatly apreciated ;)
also if the wiring kits between 8v and 16v are the same i will also keep an eye open for the valver wiring kits so if anyone knows if these actually fit the 8v lights?
Thanks in advance
  • Views 958
Bump
i saw one on ebay a while a go and it was for a 8v it had fogs the new grill and the wiring for it
Think that if you just go to VW and ask they may be able to give you the part code !!!
Foxie is your man for this 1 i have seen pics of his 8v with 8v bumper+fogs and then 16V bumper+fogs so he has probably fitted both at some point unless the fogs came with the car?
cheers lads, I've considered going to the main stealer but they recently told me the 1.9d didnt exist ina' mk4 olop so i would not rather not give them my money if they dont even think my car exists!
and I've pm'ed foxie reguarding his but still haven't had any reply, i think I'm gna have to make a loom which I'm sure i can do its mainly the positioning and the switches that I'm worried about.
