any ideas on price for a mk2 screen?
any ideas what a mk2 screen costs and where i could get a pattern part one?
Edited by steveo3002
  • Replies 13
  • Views 2k
Tenner from a scrapyard generally. Mk3 one is identical and more common. If you buy new, it'll cost an utter fortune.
is the mk3 the same item then? i thought they were bonded
id just heard chipped ones are likely to crack when fitting em , and id bought a new golf one for £30 before now
The Mk3 windscreen is identical to the Mk2 one, I've interchanged them loads of times.
Find the best one you can, if it's chipped or otherwsie cracked, leave it where it is.
I can't find a new one for less than £50+the dreaded.
oh right good call on the mk3 one then
ever seen much rot around polo screens...the reason i need it out is I've got a minor leak to the right of the pedals, i might caulk some sealer in until i find a mint screen
It happens. I'd have a good look at the battery tray and the door seals first though.
well its getting drips on that piece of carpet to the right of the accel pedal...the battry tray has been repaired already
i'll have the lower dash tray off and have a good look while theres a hose pipe on it
Probably worth checking you've got a watertight seal on the repair. Take the battery out, stick your hand over the drain hole and pour some water in.
Don't put too much in or it'll flood down the heater matrix hole.
Shame your so far south cause theres shit loads up here!
I got a few here too... :|
can anyone tell me if the window frame under the rubber has any drain holes in it?
reason i ask..I've squirted some liquid sealer in under the rubber and it p1sses straight out on the road
a pic with the screen out would be ace if anyone has one
rac will supply and fit a new window for around £60. had mine done by them and they were extremely quick!
is that a non insurance job? i dont have insurance on my screen
yep, cos i didnt have screen cover either!
