How do you get the wide wheel look?
  • Replies 26
  • Views 4.7k
Which cars did you mean in that link? :lol: theres loads
My 2 last mk4`s, both on 14x8 wheels, et15, with 195x45 tyres
Non had any arch work and both on coilies, about -90mm down i think. They rubbed on the rears a little with me + 1 and alot with 1 in the back :lol:
Sorry, those links should have jumped straight to the cars I liked in the thread. Funny actually, cos the first one I tried to link to (black) was actually yours! ;) So thanks for the reply :)
I've been looking at:
14 x 8 alloys - not picked any yet, but probably deep dish.
1954514 types - Falken
Jackson Tuning - 60/40 or 80/60
This is pretty similar to your setup, although perhaps not quite as low?
What's the rubbing like? Is it all the time? Is it severe?
I'm really not too sure about ET. Does ET15 cause the rubbing?
Hope you can answer there as I'm a bit clueless so far!
Could you also tell me what the chances are getting pulled for these? Just read that it is a legal requirements that the tyre and wheel assemblies stay within the body of the car. Why do the powers at be always try and spoil our fun??
For the general publics safety...
You need the tread to be within the arch, the sidewall/alloy can protrude a little. I don't think that's too much to ask?
Go with the 80/60 kit 8-)
This is when it was -50mm all round, its on fecking stilts :lol:
The rubbing with me + 1 was only over harsh bumps and taking corners at speeds, not severe rubbing, but rubbing all the same :lol: with one in the back it was quite bad :cry:
ET/offset works like this
The higher the offset/ET the more the wheel will sit in the arch, lower ET/offset will bring the wheel out
Example, mine were 8" wide with ET15, if they were ET20 they`d sit more in the arch, ET10 theyd be more out
AFAIK, its measured by taking the distance from the centre of the wheel, to the mounting face (where the wheel meats the hub)
Heres a bit of a paint sketch for you
Imagine youre looking at a wheel from infront/behind if its rolling
The red line is the centre of the wheel (4" on an 8" rim)
On the left, the ET/offset would be about 5, where as on the right it would be about 30 (if I've got the whole ET/offset thing right myself :lol: I'm sure i have)
@Walsh: Morning mate. Cheers for the brilliant reply, extremely helpful!! 50mm doesn't look anywhere near as good I have to agree.
Think 14x8, ET15, 80/80 will cause rubbing too or should I stick to 80/60 to be safe? 80/60 won't be stilt-like will it? lol Must be a sweet-spot somewhere :)
@Tav: I find it strange that the rest of Europe doesn't have a problem with them thats all?
Its hard to say, the kit could be really soft, so you will get some rubbing over bumps etc, or it could be really hard :unibrow:
According to this thread
http://www.clubpolo.co.uk/forum/index.php?showtopic=71224
This is on a 80/60, with 185/55/14`s 8-)
mine are 14 x 9 front 14 x 10 rear but i have had major arch work and still have the police comment on them when i get pulled for my number plates :(
but since i hardly drive it i'm not bothered lol
14x8's would be fine any bigger and police may start to hasle you even though there ok
just depends what you want really
oi walshy!!! stop whoring scarlet out!! :lol:
and the above info is correct :thumbsup:
nicnic if your worried about get the right stance then the answer is in COILOVERS :D
can get them for under 200notes off philj
Thanks guys. I'm pretty confident on what I need to buy now, so time to spend some cash ;) Thanks for the help :)
Hey Taylor, I was intending on buying philj's 'Jackson Tuning kit', why are £120 quid or so? They drop to 80/80. Is this the product you meant or something else?
Edit: Just looked again and the £120 kit is for shocks and springs - the coilover is clearly different.
So what's the difference? I didn't think I really needed to go below what the shocks and springs can do?
Edited by nicnic
Sorry Taylor :oops::lol::-p
Nicnic, with coilover you can set them at the exact height you want, some you can even adjuster the damping to make them stifffffff 8-)
I`d always choos coilies over shock and spring kit now, just because i like going uber low :-D
what he said ^^^^^^
plus i did find i had to run 5mm spacers up front with the valver wheels, wheres as i dint with coilovers do to the strut not being as thick :D
Right. Well think I'll go collies then its only another £85 quid and sounds much more flexible.
Any idea what I should expect to pay for fitting them?
Fit them yourself 8-) easy :-D
Yeah... if you've got a 7mm allen key and appropriate sockets it's a piss easy job. Did a 6n with my mate a while ago.
I however wasted about 2-3 hours looking for tools, then taking a mission to a "local" hardware shop to get a 7mm allen key, but total work time can't have been more than a couple of hours. A garage would charge maybe £150-£200 for fitting? Not worth it IMO.
Edited by tobyk
Sounds good. Do I not need any specialist equipment to compress the springs or anything?
Nah just pull the whole lot out assembled and use new top mounts if you can. Even taking the old ones off to use, there's bugger all tension in the spring, it's not gonna poke your eye out or anything.
You`ll need a long crank spanner to get the top nut off too, i didnt have a long enough one, so made this :lol:
Edited by walshc
There is that option, or a spark plug socket with spanner over it.
Wicked :) I found a full tutorial on how to do it, and it doesn't look too bad - unless I come across any unexpected complications!
Thats me sorted then:
4 x Steffan RS - 8x14 ET15
195/45R14 Falken ZE512 77V
TA-Technix coilovers
Will drop it as low as I can until I get scrubbing, which sounds like anything over about 800mm.
Might also look at some more expensive coilovers, but there is probably little point.
This has all been very, very helpful. Thanks!
Edited by nicnic
nice welding :-D
hahahaha - my best :oops::lol:
Nah i only did it expecting it to last untill i changed my coilies, I've done about 8 sets now using that bad boy :lol:
Shitty weld FTW 8-)
lol wtf did you do to your leg??
thought you had made that spanner to get that contraption off!!
