leaky drivers door
is this common on mk3's, when its been pee'in down i can gaurantee i will have a puddle behind the drivers seat and water leaking out bottom of my door and through my door card whats the problem and how do i fix it or prevent it?
Edited by scotch_kris
  • Views 706
take off the door card and you will probably find the plastic door liner is buggered, get a thick plastic rubble sack and make a new one and silicone it on, clean out the drains inside the door aswell.
