door strips
just signed up so new to this....just wonderin if anybody knows if the door strips on a polo 6n 1998 are pinned on or stuck on.....thanks
  • Replies 35
  • Views 4.1k
Welcome! they're just stuck on mate
cheers so if i get them off i will just have to remove the sticky stuff and not fill holes in?
Yep best way to do it is to heat them up with a heat gun or hot water and peel them away slowly, any glue thats left can be removed with petrol on a rag or bug/tar remover, oh and LOTS of elbow grease. :unibrow:
yeah lol i got the badges off the back 2day...hate that sticky stuff :angry: lol
might be a stupid question....but how do u get you are picture up on the side? :?
Click my Controls at the top of the page then look on the left hand side it should have a bit that says Personal Profile, under that it says Edit Avatar click on that then you can upload one from your pc.
sound, cheers mate
No problem :thumbsup:
have u took the bump strips off yours?
Not yet, I'll get around to it eventually :-D
i put coil overs on mine the other week.....but now the front wheels are angleing in at the top.....dont supose you know y?...my bruvas m8 who fitted them said its cuz its so low but i dont no.do u?
Sounds like you need to get it into a garage and have the camber and tracking adjusted, leaving it for any length of time will cause uneven tyre wear pretty quickly, shouldn't cost that much to have it adjusted.
came out of my mates house today and one of my bump strips was on the floor...so think I'm gona take them off too lol
doubt they just fell off to be honest, still if i take them off, less to go wrong, right? :lol:
ill have to pull the old heat gun out tomorrow!
let me know how much graft it is.lol
took me about 6 hours all in to do both sides of my mk3, got some nice blisters after aswell
use a caramel wheel obtainable from decent body shops and bodywork related shops, they are drill attachments iirc and it will take you 10 mins to do all your strip stickies with one of them and they only a few quid
i done them yesturday.....got moms hairdryer on it 2 loosen the glue and then used adhesive remover, then colour fast on where they came off! looks sweet now :-)
I'm fuming...
I've literally just taken my side strips off and during the last strip a chunk of paint came off with it!
Shall I have the strips put back on? If so with what?
or will touch up paint do the trick?
when i did mine it took about 6 hours and i used about 14 cans of elbow grease
tedious isnt even close...
all i did was slowly peel the bump strips off, using a credit card to loosen first off
then called my mate up and he brought round his black and decker mouse, i sanded it all right down to bare metal, and had a tin of spray so sprayed in light layers
came up pretty good, just needs lacquer
obviously can see where it was sanded down apon close inspection.
while i had the paint out i also tinted my rear lights in the same colour as my bodywork (needs lacquer too), looks well good at night, as i found out when i got pulled over last night.
he didnt seem to have any complaints about it so it must be legal :S
i suppose ill find out on my mot
^^ i take it your paint came off to? if not seems abit of a strange way to simply remove the strips!
I'm fuming...
That happened to me, i slipped right at the end, it took an actual part of my bodywork off with it, had to get it filled in, touching it up didn't work. get a picture of the chip mate
Sand it with 300ish paper until the step in the paint feathers out into contour lines,light dusting with a rattle can once every 15 mins for an hour,then two weeks later,smooth the area with some 1500 wet n dry paper with soapy water. Then Tcut it. Then polish. You should do the whole lot inside a 300mm diameter area,two hours work.
you are posts are great lol
