New MK3 Polo
Heyhey new member!
Anyone know if the clock on the mk3 Polo CL Coupe can be replaced with a rev counter?
The clock just looks so so so pants!
I've been looking at the nice white dials on internet from a GT model but I'm guessing they wont fit with my car having a damn CLOCK!
please any help
thankssss :badgrin:
  • Views 1.2k
you have to change the full clocks, ie remove the current set and replace them with a set that has a rev counter, i have one for sale if your interested...
Hey
How much you thinking?
and how hard to install, bit of an amateur you see =-]
thanks
IIRC the connections are all there already. You just need to yank out the old clocks and shove in the new 'uns. You can access the clips* by taking out the radio and the right hand vent. Don't bother trying to squeeze it through the spokes in the steering wheel - it's quicker just to unbolt and remove the steering wheel as well!
*unless you have the proper pronged tool that is.
yeah they should just drop straight in
**BUT**
you may have some problems with early/late spec car/clocks
early clocks will only work in early cars unless you are willing to mod it slightly
late clocks will work in early and late cars.
check out this FAQ
as for removing the clocks, i find it easier to remove the ash tray and put your hand up and push the pins.
