wheels
i had coilovers put on my car a few weeks back..... not sure how much its been dropped, but its rlly low. now the front wheels are angleing in at the top :? does anybody know why, and how i could sort this out?
  • Replies 15
  • Views 1.5k
That my freind is camber!
Go to a tyre place and they will wack it on a machine to give you positive or negative to whatever you need!
and will that straighten them up? what happens?
thats a negative camber!
a slight negative is ok (wheels are angled so give more surface area on the road, so more grip in theory)
as poundie said, take it to a tire place
cheers lads...the drivers side is worse thatn the passenger side i think. can they sort it if i take it to a tire place and is it expensive?
Take it to Chemix at the bottom of Mucklow Hill (look them up in the west mids yellow pages) should cost about 60 quid, I think, but they do a spot on job. :thumbsup:
sound mate :-) and that will straighten them up?
Yes. They have a machine that measures camber, castor and tracking, and they'll put them all back within the normal parameters.
cheers mate big help:-) thanks
yer i had the same problem with mine, my drivers one is ok but the passenger side is out. I've heard if you loosen the bolts on the struts and pull the disc towards you, they usually have a bit of give in them.
Edited by spilz
Best to just get it done proffesionally buddy :thumbsup:
/\/\ second that....then you know there both same....and you tyres guna ware right :)
Edited by neil_dubgt
I'd suggest getting it done asap as well because it'll eat the inner edges of your tyres and make them illegal very quickly!
Could buy a camber gauge and do it yourself? I just picked one up off Ebay for £28 delivered.
As someone mentioned, chemix in halesowen is good. My parents use them all the time and the polo will be going there later this month for the cambelt change.
thanks everyone :-) big help :thumbsup:
