MK1 Caddy pick-up
For Sale
E reg `88 MK1 Caddy pick-up
1.6 Diesel, 190k miles
TAX & MOT expired
Good points
Starts first turn, drives and stops
Body work fairly straight, all OG panels
Good tyres
Tow bar
£273 spent 3/12/07 on following
4 x heater plugs
Timing belt
Brake pipes
Fuel lines
MOT
Bad points
Rust to N/S door
Surface rust and scabby repair to bed
No tailgate
Some fool sprayed white paint on body work
Failed MOT 30/11/07
Whats needed for MOT (copied from VT30)
O/S rear reflector missing
O/S rear fog light missing
N/S front brake hose bulging under pressure
O/S front brake hose bulging under pressure
N/S front brake pads less than 1.5mm thick
O/S rear wheel bearing has excessive play
O/S rear wheel bearing feels rough when rotated
N/S rear wheel bearing feels rough when rotated
N/S front shock absorber has negligible damping effort
O/S track rod end ball joint has excessive play
N/S rear brake recording little or no effort
£550 OVNO
07968757106
  • 5 months later...
  • Views 957
Is this still for sale?
so want a caddy..where bouts are you mate?
S O L D
