respraying
well I've just finished polishing my new wheels and the time has come to spray them up but after reading the instructions on the can it says i need to rub the paint down before applying the lacqure with some 1200 grit wetndry.
is this necessary as it seems strange as i would have thought it would damage the finish???
anyone help!
  • Views 1.4k
yes you need two or the paint will not stick!
yea mate its called keying u need to do it so that the lacqure will stick. u should realy do it after priming things to be painted as well...
giv me a call if u need a hand mate, after all the things that have been painted on my car i think i could help mate lol
uf u dont use 1200 wet and dry use a tac cloth these are not as abasive and come in defferent grades for keying paint...
good luck mate
adam
it also gets rid of the texture so you have less like when you have lacquered it you need to flat it with 2000 wet and dry and buff ;)
what needs doing to laquer bare metal as I've done a steel bar but i cant get the paint to stay properly?
you need to prime bare metal before you paint it
good luck mate
adam
A tak rag/cloth is used before applying paint, topcoats, basecoat etc. its only purpose is to remove dust particles and provides no adhesion whatsoever! or maybe i wasted my time doing an apprenticeship and city and guilds course at college.
Using wet and dry or a scotchbrite pad will provide an adequate key for applying paint/primer! :-)
thank you guys
new teledials on there way!
legends
