Pic request please
Just need to email someone them so he can tell me if the clocks he has are late or early spec
  • Replies 10
  • Views 1.5k
whats the diffrence? :?
One light and a bit of red paint
Anyone??
I've got an early set of clocks you can have they have the clock not the rev counter but there is not much difference.
To elaborate. On early spec clocks there is a coolant temperature warning light located on the left hand side of the handbrake light. On later clocks this light isn't present. Instead you get a red bar at the top of the temperature gauge (which early clocks lack).
Have a look at the FAQ.
that okay?
that okay?
Hang on, that one has a rev pin and a temp warning light.
Is this an early GT one? it has the digital clock so cant be a conversion can it?
But as i read in the FAQ you can use late in early but if you put early into late the oil pressure warning has a fit.
Edited by Cymro
That's early spec GT yep
its a genesis if it helps...
See I thought that bearing in mind where the redline begins, but then decided as it's had aftermarket dials, it doesn't make much difference.
GT and Genesis clocks are no different physically
