Porsche D90's
As the add says a set of D90's 16x8 ET 52 and 16x6 ET52. They are currently painted white but do not have a curb mark on them at all so are good to be polished or just to spray another colour.
Note in the picture the paint has flaked in some areas due to fitting and removal of tyre and they could do with a clean :)
Located in Surrey
£225 ono
  • Replies 33
  • Views 2.7k
Would these fit straight onto a Mk4 Polo
need adapators to convert from vw to porsche fitment !
do they come with centre caps?
he hasnt got a porsche jason so why would he need adapters to adapt them to something they already are?
you will need porche to Vw adapters mate 4x100 obviously
Sorry no center caps. As said above you'd need adapters if you're to fit these to any VW.
£200 no offers these need to go as I need the space
are they pure aluminium?? beacuse i want a mirror finish on them, or has it got the mirror finish under the white paint??
with the front diameter not look too small on the front of a 9n??
Depends on the adapters you use to fit them. I had a high mm adpater on the front when I had them on the MK3 Golf. Wheels are not polished under the paint, you would need to get this done or do it yourself. Not sure if there steel or aluminium.
Edited by mysticpolo
have they been filled under the paint??
They come with tyres??
Edited by VeeDub9n
Hard to say as the most the outer rim is painted, but they dont look like it. If there was any damage they prob would have been welded. They are in real good nick
me again lol :-p
to check to see if they pure aluminium, at the back of the rim you could scratch it, if it is they should be the same colour no matter how far you scratch through them if the are aluminium, if they arent they will probs be black or a different colour to the surface colour under the paint (so if you would try it at the back of the wheel)
thanks
Hey, my thoughts are that either steel or aluminium would have the same colour if you scratch it deep as its a pure metal. Anyway if anyone is any wiser as to what these are made from please share your knowledge.
there alloy mate
yep, alu
would u post ?
Yeah I can post at cost no probs :)
Come on folks need these shifted :)
Whats your postcode mate. Cheers
Pm'd
