door handles and locks......
I've just recently got a new polo 1998 1.4cl 8v and it needs a bit of work doing to the body to sort it out. One of my main problems is that my door handles don't match. I've got to use 2 keys, 1 to get in the drivers door and one to start the car. I'm wanting to change both door handles to colour coded ones but I'm not sure where to get them from, if anyones looking to sell some, colour not that important because am going to get some paint work done. And does any one no where I could get some new locks and igintion from. cheers :-D
  • Views 1k
you can actually re-tumble the locks so they all work from one key.
cheers mate! where would I get that done from? Is it expensive?
Hi mate, Does your ignition lock key work your passenger door lock ? if so.........
remember..............make sure all the little metal key pushers inserted in the barrel are kept safely inside until you need to take them out, they are spring loaded. Just be careful on this job, it's not hard, but be careful.
I had never done a job like this before and i've been successful.
In order for you to get the right combination of pushers, which are numbered, you will carefully have to dismantle your passenger door handle barrel, pull out the pushers one at a time and check the number and orientation and place it back making a note on a piece of paper of it's number. Don't screw up the order or it's a ball ache to work it out.
You will have to rebuild the donor barrel in this same numbered order (preferably from the passenger side as it's got less wear).
Like i say this will work but only if your passenger door key starts the engine.
i have just sorted my drivers door lock out. The flap that keeps the weather out had been broken for a long time before i owned the car and basically all the lock movement went to pot. I could have opened the door with my front door key.
Anyway i went to the scrappers and found a passenger door handle, (not used as much as the drivers side, get my drift) removed the barrel. What you have to do is get a haynes manual find a breakers yard and dismantle the handle yourself, then you see how everything works.
HOWEVER>>>>>
If you have one key for the ignition and one key to open both the doors and hatchback, then you might have to get a full lock set and replace all your locks for a uniform set with one key.
any one else with idea's.....
