wing mount aerial
can anyone help i want to remove the wing mount aerial on my 94 polo coupe can it be done and how hard is it if any 1 has pics of it bein done that would be great
thanks guys
  • Views 790
I used an adjustable spanner to unscrew it ofrom the body work, then either u can: take the bolt off and drop the aerial into the wing and forget about it or: cut the cable and remove the aerial and pull the rest of the cable out from behind the head unit
then go to halfords and wack a bung into the hole!
