Pressed plates
Just a quick one I'm gonna order some pressed plates off the bay for my mk4, what am i best going for german font or english i prefer the look of german font but how much stick am i likely 2 get for them? cheers
  • Replies 44
  • Views 4.9k
id go for english still illeagle but not as blatent.
be prepaired for a £30 fine but its a risk you can sum up for yourself
english non banded pressed
my madre just had her bot spanked for having, legal plates with wrong spacing. no warning, letter through the door, 30 squids and 3 points. her plate isnt even that bad! 1 letter moved over. they really are getting funny about dodgy plates mind. i got stopped loads with pressed plates. got sick in the end and took em off.
You've got a MK4, so you've got an old prefix plate (X000 XXX) so it's not illegal if you've got the correct font and spacing.
If you have the new style plates (XX00 XXX) you must have the postcode of the plate supplier for it to be legal, and you must use the new slimmer font.
So basically if i get a set of pressed plates with correct english font as i was planning on doing, banded or not they are legal?
Nope, still not legal, but pretty damn close.
They look kool but i dont wanna get spanked by mr police man will i get 3 points or just a fine
Nope, all metal pressed plates for cars newer that 1972 (i think) are illegal, they're sold as show only plates
But saying that, I've never been questioned for my pressed ones on my golf, and it passed the MOT with them on 8-)
Just got to be lucky i guess :lol:
And know a tester that takes back handers :oops::lol::lol:
I'm fairly sure on your car it's legal.
If you've got a pre-2001 car (Y reg and backwards) they're legal.
If you've got a 2001-onwards car with the new style registration plates you need the new style font, and must have the postcode of the supplier printed on the plate.
You have a Mk4, which went out of production in 2000 (?) so you've got the old prefix style plates, therefore it's legal for you to have pressed metal plates with the older style font. But the plates must be reflective, the right size, with the right spacing and they must be yellow and white.
Doesn't the post-1972 rule apply to black and silver plates?
This would be a good topic for someone to try and find out for certain as this topic will come up time and time again... and also due to me having just bought a Y reg car, i quite like the idea of having pressed plates but worried of the legality of it...
thanks in advance
I cant open that first link due to work omputer restrictions....
basically it says the regulations have tightened up and all must be tocorrect font, spacing etc
If they look totally illegal. IE German font/banding then your more likely to get pulled than with UK font/no banding/GB banding.
Still illegal but I've run mine for ages now and not had any problems so far. Had it MOT'd and everything.
Don't mis interpret that as it's fine to use tin pressed plates as long as the font and colour schemes conform because it's not. The british standard also sets the level of reflex reflectivity.
A tin pressed plate must be reflective, it must not be too reflective which the reflective tin pressed plates usually are.
your quite right, apparently the tin pressed jobbies are so reflective that on police cars reg recognition system they cant see a thing aas its just a blinding light!!
This discussion is all good and well but people saying things are illegal and some aren't isn't the law i know people are speaking from experience, thats great and is what makes this forum great, but you need to quote stuff from reliable sources, I'm not suggesting that everyone is bullshitting, just that anyone can say anything is legal/illegal. :D
(You cant tell the copper givin you 3 points that some guy on a forum said it was ok but if you say it says so on a government website then you may have a better case!!!)
Rant over
Just saw the links :tear: i'll shut up now
Edited by silentbob1989
How about this for reliable - Thames Valley Police used to use them here,cars were issued with them as standard when new,and you cant change a law to make an existing car illegal (hence why cars from before seatbelt,foglight,mirror etc etc laws are exempt). As long as they conform to font,spacing,reflection and sizing,pre-millenia UK pressed aluminium plates are,and always will be,perfectly legal.
Has anyone got an e-mail address for vosa on this as i want to get an official e-mail from them with this info stating what exactly is allowed.....
Sorry Alex but you're wrong, the law was passed on the number plates themselves, not the car. Number plates made before 1st September 2001 must conform to the previous rules.
http://www.dvla.gov.uk/media/pdf/leaflets/v796.pdf#
http://www.vosa.gov.uk/vosacorp/newsandeve...ksatmottest.htm
I'm half right. I just couldn't find the right docs to remind me why.
In a nutshell, it's illegal to manufacture and supply old font plates since September 2001, but you can still get them.
If you've got a car registered before then, in the unlikely event that you were stopped for them you could argue that they were made before the new rules came in and as long as it's spaced correctly, with the right font, etc, you'll probably be fine.
However, if you've got a 51 plate onwards car, it wouldn't be possible (or at least it would've been bloody difficult) to have had the plate made before the change of rules. So you're fucked.
What I'm saying is, regardless of whether they were bought legally you'll more than likely get away with pressed metal plates on a pre-2001 car. Just like you're fine with the old font on your plates, as long as it's all spaced correctly. It's entirely possible that you could've bought them before the rules changed.
If you've got a car made after that date, well you take your chances.
So, basically......
pre 2001(51 plate).... you can have pressed plates as long as font is correct, spacing is correct, colours are correct etc.....
after 2001..... you can only have what is stated by VOSA, correct plate, spacing, font, clours etc....
i want to find this somewhere on a VOSA website, just to keep in glovebox so if anything did happen whilst having pressed plates i can show them the statement from VOSA and let them eat my dust
Yeah, but strictly speaking you shouldn't be able to buy them at all. I'm not accepting liability if you get slapped with a fine.
no no thats fine, just wanted to know for sure as the rules and regs seem a bit vague when it comes to this kind of thing.....
yeah and you could make up a receipt showing you bought them before the rule change. lol
just to piss the copper off a bit more.
anythings possible.... i have a scanner, and I'm pretty good at moving things around and copying things;
in my younger days i managed to copy a £5 note and use it in a garage LOL(i did tell her though and give her a real £5 note though, just wanted to see if it worked).
but seriously though, its legal to still make them, how are people with classic cars supposed to buy original reg plates etc..
