What's it worth?
The time has come (unfortunatly) to move on from my GT. I've realised that for the same as it would cost me to rebuild the GT engine to around 120 bhp and get all the bodywork sorted, I can buy an MG ZR+ 105. Meaning that I'll have good bodywork and an engine with a starting point of 100+ bhp rather than an end point.
I considered one before I bought the GT but couldn't quite afford it as well as insurancce and uni costs.
Is £500 too much to ask for taking into consideration all the work (listed below) that's been carried out in the past year, bearing in mind it's only done 2/3000 miles at the very most since the work was carried out. And most of the are motorway miles.
Polo GT in silver. Bodywork is solid (ie no rust) just very tired looking. In addition to the work listed below the car's had a full service with all fluids and belts changed plus various fuel system and oil additives chucked in for good measure (injector cleaner, tappet concentrate and the like). The car has ~6months MOT left on it but won't be sold with tax.
Not recipts are available for the fitment of parts as it was all carried out by myself and my old man (who's a qualified mechanic). I can however get copies of invoices for all parts supplied. Well a large majority of them at any rate.
Standard replacements
New steering rack
New rack rod end
New rocker cover gasket
New front top mounts
New radiator
2 new front wings
Re-conned exhaust manifold with new gaskets
New exhaust (from cat back)
New crankcase breather hose and valve
New engine mounts
New front brake dust covers
New ARB’s and bushes
New brake drums
New brake shoes
New rear wheel bearings
New wheel cylinders
New handbrake cables
New lower-front crossmember
New front slam panel
New ignition amp
New distributor and cap
New alternator and belt
New cambelt
New camseals (both ends)
New thermostat and housing
New oil pressure switch
New temp sender seals
New wheel bearings (front and rear)
Non-standard replacements
Denso "Iridium" spark plugs
VWII front calipers and discs
Custom Mintex "Xtreme™" fast-road front pads
Lowered 60/70mm
Kayaba “Ultra SR” shock absorbers all round
All suspension and brake components powder coated black or silver
Rocker cover powder coated silver
3 point front harnesses
Xenon headlight bulbs
Edited by keeno
  • Replies 10
  • Views 1.3k
cant see how you would ever get a gt to 120 bhp...
but anyway, i reckon 500 is a very good price considering the stupid money some are selling for at the moment.
dry
could get 600-700
any pics? I might take it for £500 today
could get 600-700
Just had a quick butcher's at the for sale section and there's similar condition GT's with less mechanical work on them carrying £800 price tags. When did GT's get so expensive?!?!
I only paid around half what they're going for now just over a year ago...
That does seem like a very good price...
But. MG ZR? 105 - so the 1.4 16v K-series. I'll just run through the problems:
Head gaskets go all the time for no apparent reason, sometimes the overheating can take the head AND block with them
Gearboxes are nearly as bad as Mk4 Polos for going
Seams on the chassis legs have been seen ROTTEN and failing MOTs on 5-6 year old examples
They destroy bushes at the front end like you wouldn't believe
Optional 17s don't like wheel bearings
Rear drums seize
But, admittedly they are quick for a 1.4. So's a Mk4 Valver though, and their only problems are the gearboxes really...
Maybe you've researched the MGs, maybe you haven't. I'd seriously consider looking at some of the forums for them for advice on what can go wrong, because something will more than likely go wrong.
scene tax mate stick it up for 900
Mileage?
Mileage?
Off the top of my head, just under 110k I think
The MG needs the 105bhp as it has much more weight to shift. The grass may seem greener,and id not say anything if it was standard - but given all the work on that fine GT,after a few weeks novelty with the MG,you're gonna be kicking yourself full on. Maybe all work and no play has killed the interest in the GT,hence the giveaway? Make sure you're doing this for the right reason.
Regarding tuning,the GT still has plenty of options. 8v,16v,alloy block,iron block,1.3,1.4,1.6,you're spoilt for choice. The MG is also at the high tuning end already. Thats why its got 105bhp,these were done right first time - Rover have even used a tubular exhaust manifold already,there's not much else but a 1.8vvt conversion in it.
