POLO 6n SHOW CAGE? HOT OR NOT?
I'm ordering a show cage for my europolow, what u think?
also any one have any idea how to fit one of these?
  • Replies 71
  • Views 15.9k
will look prime mate
out of interest, where u might get it from, is it a showcage
or a real one... do they make a mk3 polo version lol
I personally think there hot on one hand and not on the other!
Look good but i allways feel they should just be used in a car that does track/race days!
look good but
totally pointless and just adding weight with no benefit :/ Id spend monies elsewhere first
+1 :-D
Why. Id add the links to this topic for a dump-valve sound effect speaker and silver plastic sump guard,if i had them.
If you have an accident it will most likely cause you more harm than good.
A proper roll cage is the only way forward!
As seen in a mates of mines car!
Edited by mike6n
Aproper roll cage is the only way forward!
If you wear a helmet all the time. Head + full cage + accident = bloody mess.
Edited by AdamP
True!
if the cage is wrapped with the fia aproved insulation stuff is it still soo dangerous? as all the tues inthe mini near to the drivers legs arms and head are wrappe din it, is it also crucial to still wear a helmet constantly? i will be wearing one 99% of the time i am just curiously really
Well.... take a piece of steel tube, wrap it in the padding, and find a friend to wrap you round the head with it.
Then let me know if it hurt a lot.
:-D
:? hmm i will hit them i think :lol: yeah kinda get your point although them alloy cages are alot less safe than the proper fia things with the padding.
2 options..
First.. No cage and being crushed if rolled..
Second.. Roll cage and a sore head.... like being beaten with a pole...
Hmm!
No the ones that are not FIA approved can break of and shatter. It is not just a case you will have a sore head.
why not just get a proper cage if you like the look of them.
its like having a 10 inch cock and being for show only... really going to impress the girls
Heated Leathers and a Roll cage FTW :thumbsup:
2 options..
Hmm!
Over simplification at it's maximum :lol:
If you don't have a roll cage you will not be crushed. The seatbelts will allow you to duck down and the B pillars will take the majority of the force. You will walk out with cuts and grazes but be mostly in one piece.
If you have a roll cage without harness and a helmet you will rattle around like a stone in a tin can, hitting your head on everything within reach in the process! You will have serious head injuries.
What the fucks that gotta do with the price of fish?!?!?!
:lol::lol::lol:
Roll cage purpose is to protect the driver in the event of an accident, normally in a motor sport situation...not as something shiny to wow people.
Padding on a cage should be sufficient to negate the need for a helmet...after all if the cage isn't there your head would make contact with the roof/door frame which is also pretty solid.
RUF put an integral roll cage into all their cars, it fits tight to the contours of the interior and is quite subtle thanks to being trimmed as well:
You can just see the hoop coming down beside the B pillar.
Less subtle:
I'd like to put a roll cage into a Polo so that it was really subtle and blended in with the interior...perhaps wrap it in the headlining fabric.
Edited by Tav
I suppose it depends on the shape of the rollcage... but I certainly wouldn't drive my 205 any distance without a helmet with the cage in that!
No added value, whats the point in looks if it aint practical or useful
the subtle one is what id go for but i think ants after something showey?
I'm sure with quite a baggy cage or one that has the hoop right above the driver a helmet might be a better option, but then you wouldn't have a road car that requires the use of a helmet...
The point of a cage is to create a safety cell around the driver. On impact the cage will stop the car being squashed into a ball with you in the middle.
Rear cages are relatively pointless. Not only do 99% of companies say they are not for track used but they will only prevent the car crushing if you roll the car. The B-Pillars will do that anyway and your car will break traction before it rolls.
