Polo TDI
Got a problem with my wifes 2004 Polo TDI. Any time there's heavy rain, the rear drivers side footwell gets flooded. This can happen even if the car's parked and not been driven anywhere. The guy at the garage said he'd heard that water can track from somewhere on the bulkhead back to the footwell, said he'd cleaned out around the area and thought it was cured, but it's still as bad as ever.
Any help/ideas would be great.
  • Views 760
One of these things is the reason:
1.You haven't cleaned your water drains under the windshield and water finds another way.(also water drains from your roof window-if you have one)
2.Your plastic isolation(nylon) in the door broke and the water comes through the door cover inside.
3.One of your rubber cap in bottom is loose and there is your problem.
4.This is the last you should check-rubber gasket around your door.
Hope it helps.. :-D
