mk2 polo petrol tank
as above
only about 6 months old and cost £110
removed from car due to it going to the scrappie
offers around £90
  • Views 232
where you located? dont suppose you know if they're the same as the mk3s?
i am in brighton, not too sure if they are the same as a mk3 because a mk3 has a fuel pump/ sender so the pipes cone out there, the mk2 has just a sender and 2 hoses on the bottom/ front
can be used, some fettling involved.
Join the two outlet pipes together under the car and drop the Mk.3 sender/lift pump assembly in, and jobs a good 'un.
anyone?
bump, offers
