Rust On Rear Arches
Hi all
I'm sure a lot of people have had rust on their rear arches (6Ns), Mine are starting to bubble - not bad for a 1995! There is also a patch on the corner of the door...
Does anybody know roughly how much I should expect to pay at a body shop to get this sorted?
Swalsey
  • Views 1.2k
depending how bad it is? i,e surface or right thro rust then why not sort it yourself for minimal $$$$
if its just surface sand away the old paint need rust surrounding it until u get bare metal and the rust is all gone, then treat the rusty area with a rust treater and then fill and paint as normal
mornings work i reckon
Its just surface, i will see what a body shop says as to difficulity/price, wouldn't mind having a go but I want it done to last!
well use proper paints and it will last, as long as the prep is good it will hold up
