Dub update...
Anyway... So took my car to the garage to get the tyres changed.. They did it and one of them there is a dubber. He was like come back at 4 when we close and I'll do your arms and rod ends for £50.. RESULT
So I went home and made the car more MOTable... Driving back I heard a knocking sound.. I thought.. prob just the arm or rod end.. then it went crunch... WHEEEL FEELL OFF :(:(:(
Luckily I was doing about 1MPH coz it was knocking... so it landed on the wheel and not caused to much damage.. Disc was still OK :)
I got the space saver out and found some random bolts as mine had fallen off in the road somewhere... Bolted them in and drove to the garage...
I had cross threaded the hub!!!! AND the wheel that fell off I puncuntured the RIM.. not the Tyre the RIM... so need new wheels now too :(
He did do the arms and 1 rod end.. the other aint budging so neew a new rod for drivers side...
  • Replies 13
  • Views 1.6k
sorry to hear matey, did you fancy a change in wheels lol !
Luckily my wheels where too big for the car anyway.. the space saver wheel decks that corner so looking forward to some 14" or maybe go all out at get some 13's
GOnna see if 13's look good in the arch or look to small then on the hunt for wheels ;)
New HUB is £50 so I dont feel to bad now...
Why did the wheel fall off?
Surely the garage is liable?
No garage did back wheels... I was working on front at mine to get the track rods etc off on sat and must of forgot to tighten one up fully is all I can think.. Unless the kids have been messing with the dub...
Such a bitch.. I have a feeling casteleetes or Steffan BCW's are in order ;)
Edited by T700BES
Sorry to hear that mate.
Steffans afre becoming common amongst 4/5's so think the castellets would be better. Personally I think the stefs look better but I missed the castellets I had on my 4.
Hmm still not sure on the castellets.. Paul_Gti had them on his GT.. looked nice.. just dunno if it goes with the Mk5!!!
Hmmmmmmmmmmmmmmmmmm
Maybe ill colour code the stefans ;)
the same thing happened to me, i fitted my coilovers with the expertise of walshc and bro and because i had 16v wheels the offset was high and rubbed on the inside of the coilover, so i went and bought some 5 mm wheels spacers to give some clearance. Walshc said make sure you get longer wheel bolts but i put it off and off and then.......
i was going down the bypass at 50-mph and the wheel fell of, i was in the fast lane and came to a stop, the tyre had wedged under the arch and i had snapped the spacer and lost all the wheel bolts. so i had to get my mate to rescue me but it was pretty sketchy as i was in the fast lane with my back facing into the other lane with a jack under my car trying to gather some wheel bolts... :lol: but mine wasthreaded too :sad:
Anyway my point was that you could try and get the hub rethreaded, i got mine done its a method called hellicoiling and it inserts a new thread into the original, its supoosedly very safe and touch wodd i have had no problems, it was 30 quid and i didn have to bother with the hassle of changing the hub as its not the easiest job if stuff is siezed.
and yeah colour coded steffans would be very nice
good luck mate
Exactly what happened on my mk5 :lol:
Luckily i didnt fuck the hub up, i just got a nut snapped in there but got that out, and bent the wing, which still isnt repaired after 3 months :lol:
I only fucked the hub because the bolts had fallen out and I had my spare in the boot and some bolts.. The bots were not for my hub.. so I cross threaded the hub...
I am doing my car properly now so I would prefer a new hub but thanks for that info jonny!
What do we all think of my space spaver.. LOOOOOOOOL
Biscuit wheel yeyyyyyyyyyy ^^^^
colour coded and everything
Its even the same wheel that fell off on mine, scary. :lol:
My spacesaver, 13inch vs 17inch :lol::
Helicoils are great. They're a hardened steel thread,look like a spring,and are particularly good for beefing-up manifold threads. I had a tca bolt snap on the coupe-S a few weeks back when i clipped a roundabout kerb with new wider wheels,tore out the braided brake pipe,tore back the wing,tore out the driveshaft,made a right mess. I still managed enough of a roadside bodge to crawl home.
some one helicoiled my rear hubs n i would advise everyone against doing this, one day i was swapping wheels around and on each wheel i ended up with only 2 bolts holding the wheels to the hub the others had been stripped as the helicoils just pulled out, i was soo happy i wasnt driving it at the time!
