Door Strips - Problem
Decided to take off my door strips, got one side off fine, no problems with paint or anything
Then started the other side, took 1 part off all good then on the next part (the door) a bit of paint come off. Nothing can be done so i started to take the glue off the other side. Then on the other side at the back bubbles had appeared, unsure what to do i carried on taking the gule off the other side. Then i checked again and bubble were appearing all over the other side on the door. Nothing was put on it so the paint must be reacting with the air? I need to get this sorted asap does anyone know where i can get this sorted or what i can do. Why has it bubbled on the one side and not the other?
Where the strip was taken off on the back (smaller strip):
Where the strip was taken off the door:
Nothing was put on this side i just left it whilst i took the glue off the other side then bubbles appeared
  • Replies 9
  • Views 1.6k
i would imagine a spray shop could sort you out. Once its bubbled i wouldnt have thought thered be anything you could do to fix it...
how much u reckon its gonna set me back, its only along the strip inbetween the glue
Should of got an old card and pushed your way through the dry glue gently, it would leave a layer on the panels but after that can be removed. would save heatin the glue up and peeling the strip and taking the paint with it.
That happened to a part on mine. Now it looks gash because I couldn't be bothered to fix it :lol:
The other side went fine and the other side i did exactly the same making me think that the paint has reacted with the air? I'm gna go to vw see what they say its still under the 12 year warrenty. If that fails I'm gna buy some colour coded mk5 bump strips i think
VW won't do anything since you're not supposed to take them off
i expect it's had paint in the past it'll need to be repainted to fix it
mayb say they were damaged and needed replacing
12year warranty ? WTF ?
