Bike carbs from r6, fuel pump and filter
Usual change of plan :lol: , ideal for 1.3's inc Gt's. Propely set up you should see 100bhp.
Set of r6 bike carbs in good condition. £70
Matching r6 fuel pump. Best to use in conversion as runs correct psi for carbs, self regulates and has return! £30
Airbox with fitting plate and rubbers, used to fit your socks/filters. £15
Will do the lot for £100 collected (NE) or £110 posted. The carbs alone go for this on the bay.
lots of post on here with the info you need.
Edited by ashley555
  • Views 448
what a mk3 1.3 or a mk4 1.3 ????
1300 cc ish. can be jetted for engines 200cc ish more or less as a rough guide.
any 1.3 just need manifold and setting up.
spot on would be suitable in thoery for any motor 1.1-1.5
you still got these? i will buy them if you have..?
pm'd
