Sill trims on a mk3 square...
Currently in the process of fitting my sill trims to my square, however there are no rivet holes on the the square for the sill trims to attach to so what is the best way of attaching them; i'm thinking of self tappers and or sealant...
  • Replies 11
  • Views 1.8k
tigerseal without a doubt
cheers mate, how long does it take to dry cos the problem i'm having at the moment is the sill trim slipping while i'm waiting for the product to set...
what you want to do it tape the arch on with masking tape, whilst the sealant cures. how long this takes depends on the ambient temperature
nice one Jon, i'll get some better masking tape than the shit i was using... check my avatar- I have rear square arch trims now also ;)
electrical tape works well, doesnt leave sticky shit on your paintwork either
I would have thought electrical tape was more likely to leave sticky shit?
Tigerseal will need a few hours to cure. What I tend to do is put some on both faces of what you want to stick together, leave it for about 15 mins and it get very sticky, then press them together and it should hold better. You'll still need some masking tape over it though.
thanks for the advice lads, will pop to the mdc at lunchtime and attack it later!
it will if you leave it for weeks on end, but its fine for a couple of day. i often use it for masking up wheels and panels when doing diy spray painting! its cheaper than masking tape cos i can get it for free!
Its good for taping around peoples faces as well.
When your having a bit of childish fun while working on cars.
The good thing about that Kam,is that it contracts - slowly squeezing the victims face.. Anyway,just rivet them on. I got a rivet gun for a fiver. Hold trim in place with one hand,mark hole with pen,drill,rivet. It'd take one minute each side,and is how VW did it. Same with the arches up through the lip.
cheers mikey, at this moment in time it's held on with some strong sealant but will look into riveting it on in the future...
