DIY dent removal
Iv seen these work on various videos, i know they probaly wont work on very small parking dings but i have two biggesh ones on my roof which I'm sure will pop out quite easy.
If anyone can advise me otherwise I'm going to give it a try.
  • Views 1.6k
it may work on the odd one if your lucky but it's not as easy as you think otherwise proper paintless dent repair companies would eb using them instead of rods ;)
yeah, as martin said really, if they are in the roof try pipping them out from the inside?
Bare in mind that there will be a weak spot wherever you pop them out, especially in big panels like the roof and bonnet. The slightest tap could cause it to pop back in again! I've given up on my bonnet now, I pop it out and it just pops back in next time it gets driven.
Yeah i know what your saying, problem is the dent on my roof is near the edge were the roof lining is tight so i cant push it enouh to reach the dent. Which is a good thing and a bad thing because its a bitch to get to but its got some extra support which hopefully means it wont pop back in.
drop the headlining
Yeah i went out the other day full of motivation, opened the boot, removed the seal and saw how brittle it was to the lip of the boot bodywork and thought no chance.
you can get those things from halfords i think?
