stupid polo
Yesterday driving home from work just entered some country lanes went into first corner at about 40 nothing stupid.
Then sundely herd like a bang. then the back left wheel was making a knocking noise really bad.
So any way i pull over and stop looked at my back wheel and i only have one wheel nut in.
So ring my dad to bring me some wheel nuts as i was only like half mile from home.
He brings them we go to put them in and it turns out the bolts have not come lose but have actually snapped inside the hub!
WTF!
what could cause my bolts to snap? well confused.
Gonna try and drill them out i think
  • Replies 54
  • Views 4.3k
hmmm, anythingt to do with to much pressure if the spigots on your wheels are an incorrect size? then going over a bump has put way to much pressure on thebolts and caused them to shear? maybe with coilies being alot firmer they have also put more stress on things not helpingt he situation? :lol: all ideas but probably of no use :lol:
Edited by POLOMON
Yeah maybe the center bore on the wheel was too big for the hub?
spigots rings are fine they fit over the hub sit perfect I've had the wheels on for nearly a year now
What wheels were they? RH cups?
yeah mate
JESUS CHRIST pal thats a shitter!!
cant believe something like that could happen!
the only thing i can think of is possibly overtightening of wheel bolts
Hope you get it all sorted pal
Guh-ay.
I'd say you've over torqued them. Do them up as tight as you can with your hands with the standard VW wheel brace... that's a pretty good way of getting them torqued right.
How ghey is that!
How did you get the car home?
thing is tho they have been that tight since christimas and its taken till now
unfortunately, if theyve been that tight for this long then all it would take is for one to snap, then it puts extra strain on all the others and they all snap...
How ghey is that!
drove it home on one wheel nut at about 5mph! was only about half a mile away and was one road so just kept waving people past me lol
Edited by Djsimmy
I'm not sure if wheel nuts get hot on the rear either, if they do this would have some kind of effect.
This does sound like over torqued to me.. but if you get the wheel off you shouldn't have to drill them out they should spin out quite freely..
you might possibly be able to weld a nut on to the stuck thread and take it out that way?
Just don't weld it to the hub accidentally :lol:
but how can i grab the wheel nuts lol there like flush inside the hub ill have a propa look 2night
Tit!
That wasn't to say I've ever done it lol :lol:
You never know some people though :paranoid:
I think your gonna have to try drill em out mate, the welding option I would say is a last resort.
Not really much else you can do
yeh i agree with nickyboi dry dril them i wouldn try welding it wil probably go wrong lol you could try tappin a groove for a flat head into them if drillhng doesnt work. Bt sorry to hear about that.
Try a stud extractor.
As the heads have broken off in my experience the remaining studs should spin out quite freely, so there should be no need to weld/drill anything. If you had rounded the nut head then welding/drilling would be needed. The only issue you might have is if the remains on the stud is sitting inset into the hub/brake drum. Then a reversed tread drill bit extractor thingy (I dont think thats it proper name :) ) can be used which should get it out quite easily.
Edited by max_crox
ill give it ago when i get home mate cheers for help
