Salzmann Top Mounts
Where stripped down a re-charged with fresh grease about 2000miles ago. No longer need these, designed to fit stock polo shocks (M12x1.5) and give adjustable camber via an ecentric bearing and then lock off.
£100 ono
Can bring these to GTi Festival.
Pete
  • Views 709
how many degrees of camber can these give and can you supply rear camber plates?
Around 3' I believe, I no longer have the Salzmann instructions unfortunately- will also depend on your suspension set-up. We don't do the rear camber plates, sorry.
