Rear wiper removalism
Chaps, i know this has been asked many times but i want to take the rear wiper off my 6N as the motors has died and i dont use it anyway. I've tried using the search function to find info on it but i cant bloody get anything :?
I've heard you can use a rubber bung to fill the hole in the glass, can these be bnought from halfrauds and also does anyone know what diameter i need plz ?!
Thanks advance
Hey, theres a couple of ways you can sort out the blank, either buy a bung, halfrauds maydo them, if you've gotta a good one nearby. you could stick a 2p the the wiper blank, fill it then spray it, or buy one (this is what i did). I think i got mine of net from colt society.
In terms of taking the rear wiper motor out the haynes manue will tell you how to do it, just remember to block up the washer pipe
Chris
use a hacksaw n chop it off
what i did is got a 10pence pice and drilled a hole in it and put a bolt throught it, superglued it in the bottom of the blanker plate from the wiper and fillered in the rest or the hole in then painted it and bolted it in , done
i took the wiper off and used the existing wiper surround plate jammed a piece of plastic bigger than the hole behind it with a bolt fibreglassed onto it then filled the front and wrapped it with vinyl, only took about an hour or so and cleans the back up a lot
venom do a proper blank for 6n rear wiper holes but can find them on there website only the universal ones but heres a link anyway
http://www.venommotorsport.com/manufacture...duct=WiperBlank
but it does say they supply them for a massive range so give them a call
luke
just matz do blanks aswel,when i did mancmikes we got a pack from 20mm to 25 mm and they were very ight but finally went in so i woudl say 20/20mm take yoru rear plastic blank in halfords and try a few :p i put one in the actual boot and one in the plastic surround and siliconed the plastic surround back on the glass/boot
