rear philj kit adjusting
how do you adjust the rear struts on the philj kit?
cheers
  • Views 975
Take the dampers off. There is a circlip on each damper body. Prise it open with a long nosed set of pliers or something else suitable for the job. Then move the clip to the desired slot to raise or lower the car. Refit suspension. It'll become obvious when you get in about.
Just like that :-p
ah i see cheers!
