Rust Repair
The rear arch on my 6N has rusted a bit, i also have various stone chips that i would like to fix, although i could perhaps do them myself i think. The drivers door has rusted at some point and been repaired, but the paint doesn't match, any rough idea on what a garage would cost? I understand its a pretty vague description, but ball park figures?
  • Views 2k
Do you mean how much would it be to fix the mentioned problems or a full respray
Well ideally i would just like to have the parts repaired, but i don't want shit colour matches on em.
Some places charge between £50 - £150 per panel depending on the prep work required, colour matching and obviously the size of the panel so if you opt for a cheap job your most probably get a shoddy finish
so because my main area to be worked on is the rear arch, would the company have to respray the entire rear quarter panel? thats a fair size, or do they just work on an area around the offending patch.
What they will do is remove any rust and rub down the surrounding area so that it is to a workable stage, the area will then be primed for painting, the patch will then be painted and the colour will be blended into the original colour, simply because paint is so difficult to match 100%. then they'll add any protective coatings that they do apply, some do, some don't, make sure you kno what they are planning for the area, and that it matches the finished article that you want to see. If you aint happy with it, you never will be
how much is a full respray going to cost? don't need one, but perhaps for the future.
