Fuel Tank
Gday all.
As you can see I'm a newbie to this forum, feels like being in 2nd form again! My prob is a leak on the fuel tank of my 89 polo ranger. I can see the leak and as far as I can tell its coming from the feeder pipe to the tank. there is 19 years worth of muck that I removed and i think i can now see a rusted section where to leak is coming from. I have drained the tank and removed the strap and bolts holding her in, but for the life of me i cant seem to get it out. i'm being an idiot i know, something I'm missing me thinks. Any advice would be welcome.
This little car has been in the family for years, gotten it off the wifes grandparents a few years ago and its now my little run around. would like to treat the rust around the wheel arches and get her running smoothly. The cars been a good little runner and not given us any grief at all, so think she deserves some tlc.
  • Replies 15
  • Views 2.5k
welcome to clubpolo
welcome to clubpolo
cheers, but think my fist post was in the wrong section!! oops!
sometimes you have to drop the rear axle from one end of the body mount to get them in/out, then its just a case of wiggling it about until it all comes out. I guess you have already removed the metal ring holding the rubber grommet onto the filler neck at the top of it, where the fuel goes in?
As for your rusty arches depending what there like really if its just surfcae then sand them back/wire brush them back and rust cure then paint and fill or if there really bad get the either some replacement panels or measure what u need and get to a scrappy and cut some old stuff out then get back and weld in the new metal, fill and paint
job done
Will
Edited by mad_will
I believe these fuel tanks are still sold brand new,as a pattern part. Not exactly twenty quid mind,but if its going to last another twenty years its gotta be worth considering. Its a popular problem,though I've never needed to repair one myself. Consider whether welding a collar over the area would be effective,like a flange or cone-shaped pipe reducer,if one will slide over/down the filler neck.
generally used ones are quite good it all depends on the cleanliness of the car as its a major dirt trap there so everybody with 2 and 3 polos should clean and check it like once a month or so and make sure its clean. (welding a tank) unless its detached from the car, drained of all fuel and washed out with something. No way would i go near a tank until then as one spark, closed tank (bang)
thanks for your comments will, i'll be having another bash this eve. when you say the grommit do you mean around the top of the feeder pipe, it has a drain for spillages that runs down next to the tank. there are 2 overflows there. but there are 2 rubber tubes that run up into the bodywork, they are a bit of a mystery to my, and also one a bit lower down, below the overflow in the feeder pipe. the hayes workshop manual doesn't give much info when it come the petrol tank. a bit annoying.
I'm pretty sure the ones into the car are breathers/overlow tubes. i was referring to the main rubber seal of the neck to the body where you put the gas in. there is also a pipe on the reverse of this about 5 inches down from the filler cap which can be quite tricky
Is there not a direct bolt/s to the chassis aswell as the strap?
Oh the main rubber seal, yes thats off, now just need to get off the breather pipes, as you say, they tricky.
as to the bolts under, i've got them all of. she's a moving, just not enough. lol. i shall endevour and she shall not beat me!
!don't weld your fuel tank!
Even if you have rinsed it out with water
There's still fumes in it.
I fixed mine with araldite last year - still working!
as i say might have to remove the bolt from the end of the beam and the top mount on the suspension that side and just drop the beam outa the way but easy enough in a day
cheers for all your comments guys, got the tank out after some wiggling and stuff. did not need tp drop the axel which was a bonus. thinking i'm going to replace rather than repair. would last longer.
I did mine in my 86 mk2 last weekend, never understood why everyone says to drop the axle, I had no need to (unless its different on a saloon?) I found what helped best was getting the rear of the car jacked up as high as possible, so when the fuel tank was dropped it didn't require much wiggling to get the filler neck out.
Replacements from GSF are £62 + VAT, I managed to get it at trade (£63) all in when mentioning CP, didn't even have me card! It fitted good aswell and didn't require to much manipulation of the neck to sit right.
Also I actually found the Haynes was pretty helpful (for once)
Nothing wrong with welding a tank. Watched my uncle do an Escort tank. Few simple steps:
1) Ensure no sources of ignition,including smoking,electrical switches etc.
2) swill tank in a well ventilated area (outside) with last couple of litres in it.
2) Tip tank over and empty out all the fuel into a bucket,immediately into a petrol can via funnel.. Cont..
3) Attach a footpump hose to the outlet,and attach the other end to the valve on the spare wheel (this will blow most of the fumes out).
4) stand out the way of the filler hole and throw a lit match in. Yep. This will remove any remaining fumes/dribble of fuel.
Note - never put water in there.
