headlining mk3
dos anyone know how to take the headlining out from a mk3 polo cl coupe without damageing it
i'v taken the Aerial out from the wing now I'm putting one on the roof and need to run the wire from the roof to the head unit
any help would be great and if anyone has pics on how to that would be better
thanks guys and gals
  • Views 1.2k
As far as i know the headlining only comes out after the glass is out. Could you drop the lining at the tailgate & attatch the cable to a long thin cane or fishing rod, then feed it through to the front corner. I'm not sure how you would get it down the A pillar without seeing it
I didn't do it myself, but the wiring for my beesting goes down the back pillar and feeds along the passenger side of the car.
There used to be a guide written by Keith Lee on the old clubpolo site on how to do it.
HTH
open the boot, remove the rubber seal, now with a hair dryer heat the liner where its glued, carefully peal it back. you should be able to get enough back to get to where your fitting the ariel. as for getting the wire down from that point I've no idea coz i joined my one to the original wiring to avoid that issue, but i uess thats not an option for you seing as your one was originally wing mounted.
thanks guys very helpfull info gonna sort it out at the weekend i think will post some pics on how i do it think it will be the down the pasengers side sounds like the best way of doin it
From memory that's where it goes on the g40 too
