A few questions about treating rust
I need to treat some rust on my car. I have baught Hammerite Kurust and it says 'apply top coat after 3 hours' might be a really stupid question but what is a top coat?
Is there a way to blend the rusty area's new paint with the existing paint as i really don't want a visable line where the fresh paint starts.
Thanks in advance!
  • Views 774
top coat asin PAINT the colour of your car. dont put a masking tape line up half way through a panel and u wont get a abvious line if the match is godo for the paint it wont be too bad.
I'm sure one of the wissez liek martin will explain in a short while :p :lol::ninja:
top coat will be your primers and paints, you have to give it time to let the hammerite do its thing. easiest way is mask off your glass in the surrounding areas then shoot your primer, let it dry and wet sand it then apply your top coat (colour) and clear, let it dry and then wet dry and buff it and as long as you have the right paint and your OG paint hasnt faded then it should be all good
