Painting the interior
I have stripped all the sound deadening out the car.
Headlining has to come out so I assume the rear windows need to come out? If they do then I am going to spray the interior of my car.
I have no real spraying experience but I have a compressor which I have been told is good enough for spraying but the tank is fairly small so I can only do a pannel at a time. So might take 4 or 5 times but spraying the interior is possible.
I plan to lay down a few layers of white primer, then give it a few coats of white. I am not after an amazing show finish and I know this will not happen any time soon but does anybody know how to actually do it.
What primer do I want, what paint, How many litres etc.
What pressure do I need to have the compressor on. I got a cheapo spray gun from machine mart. Will this do?
Whats the best way to mask up the doors. Pics of work in progress will do [already seen heg123]
thanks for your help.
  • Replies 14
  • Views 2.2k
right if its a mk3 then yes rear windows out to remove head lining
so everything out the car all gunk cleaned off of floor and washed out with grease remover and totally clean. sand and prep everything up so if you want anything smoothed out nows the time to do it.
final sand all the areas to be sprayed with about 240 grit paper then air line it all out and tack rag it off
you say you have a gun and its cheap so you wont really be able to mess with the presuure so much but i tend to run 40psi for primer so it gets it thro the gun easier.
as for primer id recommend a cellulose primer as its easiest to spray at home and is real easy to work with, get the can of it give it a shake for about 5 mins (with the lid on :)) then open it up and give it a stir, chuck some in the gun and get a piece of paper set up on the wall and hold the gun 6 " away from the wall and pull the trigger, you should have a fan pattern about the same size as the distance from the wall? if not fiddle about with the gun settings but usually the screw behind the needle will adjust it. then inside the car start wherever you like and give it all a good coat but not to get any runs.
let that coat flash off for say 15mins then get another coat on it, i always try for 3 coats of first primer so you have something to sand.
when thats dry rub get a can of contrasting paint in a rattle can and mist spray that over it, let it dry for 5 mins then start to sand with a block and this will remove the mist where its high and leave it where the body is low and show you if filler is required anywhere. once all thats done then finish with about 500 wet sandpaper and dry it and tack it off
as for your colour id say use cellulose as its easy and cheap enough to use at home, gt it in whatever colour you want. again shake and stir it then put it in the CLEAN gun and spray again using the same technique as the primer and aim for around 3 coats depending on coverage.
wet sand it with 1500 then shoot some clear and leave i to dry.
" spray tips"
Keep the gun clean
Hold the gun 6" from the surface
Keep the nozzle of the gun parralel to avoid uneven paint
Dont touch surfaces to be painted with skin as it transfers grease
Just enjoy it and have a bit of fun its not as hard as you think but the more time spent on prep the better the final result will be
Will
Will thanks for your help. Will let you know how I get on
coool get pics up as you go along and it will help other people out. just make sure everything is cleaned and wiped down before you spray ANYTHING so you dont get reactions
I'm no painter so correct me if I'm wrong but won't 240 grit be a bit to harsh?
Before primer,Kam? 240 before primer,then 500 smooth before paint,seems a bit of a jump. But i think its a bit pointless to get another stage in during the primer. Being an interior,it'll benefit from plenty of primer,so the 240 marks will be well covered. A coat of etch primer might be worth doing?
well not doing the 500 and going from 240 into paint will leave scratches in your final colour layer wouldnt it
right.
got abit excited today and did abit of welding on the turrets.
Windows came out easily enough which makes me think that most thieves are stupid as they try to break in through a door.
Headlining came out.
Started to flat off all the paint in the boot area, and generally key up all the surfaces.
Will finish prepping for primer tomorrow and then will lay down some primer the day after. Pics going up from todays action in abit
This morning I have managed to secure any equipment I want from a matey spray shop so thats all good.
Spoke to a paining type person.
I need etch primer + hardener as I have gone down to metal in place.
I then need a high build primer + hardener. Was told to get Grey primer as it is easier to see where I have missed when spraying white
Comes in at just over £40 so I am happy.
Am going to key the whole interior with 240 grit/wire wheel then get primering. After the etch primer I am going to go for about 250? Then follow wills instructions from there. Thanks peoples
cool cool good progress and keep us updated
um maybe thin the product slightly more and make sure the gun is absolutely cleaned out, maybe run some of the products thinners thro it and then try upping the pressure. also think about slowing down to get more paint onto the surface, but otherwise great progress
you run the primer / paint through a strainer ?
i imagine he hasnt but i dont always and its sometimes down to the mix, but defo a strainer helps no end
I didn't use a strainer. I just stirred it for a while. The gun was cleaned before I started using it and thinners was going through when I was trying the settings out.
Realising my primer and ultimately paint is going to be far from perfect I decided to prep the interior and see if I can rope a mate into spraying it for me.
Will I am only at junction 24 of the m25. You fancy some cash in hand work?
nah sorry dude its kinda far for me as I'm down in kent and thats a 2 hour drive each way easy. its do able but need some serious $$$$ I'm sure you or your mate will be able to get it done anyways and looking good, plus its orange peel in the colour then flat it back with 2000 wet and dry then clear it and buff it up.
