iv just gt a polo
1- the engine is rusty whats best thiing to giv it a shine bk.
2-the interior on roof is dull and hangin off i want to change it and if i buy a diff colour is it easy to fit?
3- the door interior is crap can i spray it and if i do will it look good
4- can anyone find me a fao on how to fit bucket seats there universal
1- aint got a clue
2- i beleave to change roof lining some windows have to be removed, never done it so i may be wrong
3- doorcards can be sprayed however it would be a lot easier to source some second hand in a better condition
4- you will need to make custom subframes, use the search function you might be able to find some info
where are you located, may be able to help with doorcards?
engine is rusty? I'm assuming you mean the block and rocker cover and air box cover? if so sand em down, rust treat them and spray them up with a bit of paint in your choice preferably heat proof paint
depending on what polo you have rooflinings are easy/hard to change, but do able
I would go to a scrappys and get another full set of doorcards to drop in as its a lot easier and will look a lot better as well
with your buckets your going to have to look at the way they mount then find a way of securing them into the car and THEY NEED TO BE SAFE
1.) whip the rocker cover off, sand and repaint with high temp paint.
2.) Most of the rear windows i believe must be removed to get the lining out in 1 go. i've been told it can be a very annoying job on a mk3, not sure about other mk's. If the lining is hanging, maybe it has detached from where its held to the roof?
3.) I agree with Grant. best off getting some 2nd hand ones from a scrappy/parts for sale section on here. If the seats are manky too, you could swap the whole lot over for a fresh look and upgrade if necessary (gt/g40 sports seats!)
4.) You're in the same boat as me! If you're seats mounting points are on the bottom, you could use the framework under standard seats to mount them to the runners. If, like mine, they mount on the sides, panic!
well they r on the side my seats lol and il go and av a look at the scrapyard n ye it is the rocker box i ment il do that on a sunny day I'm not keen on takin my windows out lol erm i dont no what mark my car is all i no is its a 1991 j reg polo and its white but iv found white cars look better with blacked out lights n stuff and black cars look good with lexus lights n stuff thanks for you are help ne way
