Mk3 rear badge
As the title says really, i want to remove the VW badge from the back of my mk3 and turn it black. How can i get it off, also how can i get it black? :lol: Also would this work with tha actual 'polo' badge? If i remove this then how can i stick it back on?
Thanks Olly
  • Views 1.2k
The thing I always do is get a screw driver, put a bit of masking tape on the end of it then carefully pry the badge off the back of the car. The tape stops the paint from scratching so easily. The same can be done with the Polo badge.
You just need to key the badges with a red scotch pad. Then give them a coat of plastic primer. Once you've let that dry key it off lightly again, give it another coat of primer. Key it again then paint the bugger!
Remember light thin coats are better than a thick coat!
You should leave around 24 hours between coats if you want to do the job spot on. But I find leaving it about half an hour in a warm cupboard does the trick enough.
OK sweet thanks :) Wots the best sort of paint? :lol: Is it not like the front one where you can somehow paint strip it?
i used some halfrauds primer and some black auto paint i picked up in poundland looks good tbh!
ok sweet il give it a try :)
