Whats my G40 worth?
I'm dabbling with the idea...again... to sell up. I'm tempted to get a lupo gti but to get some idea of money i need a rough guesstimate on what my g40 is worth to decide wether its worth selling or just keeping. I'm not asking for your opinion as to me selling or not LOL just how much you think is a reasonable price considering the following and the current market. ideas on wether to sell the plate seperatly or not? i may keep it like i said i just need a rough guide as to what its worth, to see what i can afford to do.
Make:
volkswagen
Model:
polo g40
Year/Reg:
1992 original plate J987TPY
Mileage:
135k
MOT:
january 2009
Tax:
end of august 2008
Good points:
original G40 in white. original wheels fog lamps, tilt slide steel sunroof etc.
thatcham Cat 1 alrm immobiliser
golf rear door handles without key holes with armour door plates
only mods are:
H&R cup kit
polished rocker cover
new braided charger oil feed
Gladersiete roll bar thingys
PSD braided brake lines
Vag de-ct pipe
Full blend charger rebuilt 8k ago.
gearbox rebuilt
fan switch mounted in blank in the dash using a rear screen switch fitted professionally
this is gonna be long but in my ownership, 34k its had the following:
95% from VAG or if not they are the same items as vag would provide i.e. bosch.
fuel pumps (both)
injectors
fuel tank (waxoyled)
hall sender
coil
vacuum hoses
new shells and bolts bottom end
head rebuilt with new valve stem oil seals
head bolts
waterpump
timing belt
thermostat housing and associated parts
new oil seals and gaskets everywhere, head/rocker/cam/crank etc etc
knock sensor
lambda probe
blue temp sensor
black temp sensor
oil dipstick
earth leads
ignition leads
dizzy cap
rotor arm
battery
air filter
clucth kit
clutch cable
boost pipe jubileee clips/nuts bolts/ everywhere
brake lines replaced at last mot with genuine plastic coated steel vag ones
g12 coolant
radiator
fan switch
oil changed every 3k miles without fail
vag exhaust mounts and rubbers
mid section is almost new vag.
charger belts
discs
pads (last summer)
full brake fluid change MOT time
engine mounts
rear wheel bearings rear shoes
vag rose jointed steering arms (both sides)
the following parts have been powder coated
fuel pump bracket (fitted with new rubbers and bolts from VAG)
charger mount
rear engine mount
tunnel brace
Interior.
original apart from steering wheel which is an italvalanti one.
seats rebuilt with new cables and runners
slight fading on rear seats but no broken cables, rips or tears or damaged sponge whatsoever!
audi tt cover on clutch and brake and the original throttle powder coated satin black.
vag mats
new leather gear gaitor
no radio equiptment just a vag stereo storage compartment
gearbox rebuilt by JP race about 6k ago with new bearings and seals and refitted with new vag release bearing and vag gearbox oil.
The car is mechanically spot on. it has a slight miss fire on morning start up but drives really really well, actually i dont know why i want to sell. I will not sell the car until this sorted and am 90% sure as to what this is so lets presume this is out of the question as it will be sorted.
I am a complete fanny about this car, any amount of money is spent to keep it right!
i have a wallet of all the reciepts which i dare not count up
Bad points:
back box is non genuine g40 and will probably only last another year
the body work
I'm going to be more critical than necessasy.
the worst is the boot, its rotten on the inside and will need replacing but the car will come with a black tailgate which has absolutly no rust whatsoever which I've been storing.
the rear corner pices below the lights have started to rust and need sorting. there is a couple of small dings (minor)
there are a few small bits here and there. but the car overall is structurally great and to make it totally mint needs a good strip down a full shoot and putting back together. the body itsself is solid! the sills are great! (nobody is allowed to touch them with a jack!)
the main bits that need sorting are replaceable panels. but the car will come with 2 new unfitted vag wings which is doesnt really need, a boot, a passenger door. ALL TOTALLY RUST FREE!!
and a boot lid vinyl! unfitted!
I cant think of anything else to say, this is one amazing G40 it just needs someone to finish the body work off and it will be even more amazing!! doesn't leak anything whatsoever! as far as I'm convinced its had all the money spent in the right places it just needs some one to detail it!
i wont sell the car to anyone, this is my baby, if i think for a second your gonna fuck it up i'll tell you and you wont buy it! that sounds harsh but i can afford to do that!
sunderland
Pictures:
loads of pics of everything I've mentioned some are from last summer but its pretty much how it looks when its cleaned up!
Price:
your recommendation boys.
Contact details:
  • Replies 54
  • Views 5.2k
5 knuckle shuffle n a curly wurly?
ad buy it :D
3500 - 4000 :)
Edited by neil_dubgt
ad buy it :D
3500 - 4000 :)
see i dont think its worth 4k not even with the plate.I've been thinking more 3k-3.5k with the plate?
but mate, you consider the hard work put into it, nearly all of its vag, u said you are sen it runs spot on with no leaks or sqeaks all the new parts. I'm pretty sure it almost runs like a new car
i mean even 3500 for your mint G is a bargain.
£3k maximum and sell the plate seperately.
Very nice car though 8-) Keep it
I'm thinking around that mark. any less and i'd keep it, it wouldnt be worth me selling for under 3k. plus i think thats reasonable. 3k with the original plate. which i actually still have the dealer fitted number plates.
id say 3k mate and someone will snap it off your hands, and sell the plate desperately but only when you get the right offer as tbh is prob one of the coolest g40 plates (if your a geek and you know the engine code that is)
3k gota be bargain of the year :lol:
i thought the knuckle shuffle and curly wurly was a pretty good deal to be honest
:lol: gota try it aint you
If i was in the market for one i would give you 3k
not considering the current prices of g40's at the minute, i think thats ok. its by no means perfect taking into consideration what I've said. but if i sold it next week, it'd have had a checked charger with oil seals replaced if necessary after 10k since a full rebuild, new charger belts, oil/filter change new plugs about 2 weeks ago, timing set up, fault codes checked and cleared. the miss fire sorted (this is all based on this weekends activities!).
Edited by supercharged spaniel
can you really not afford to keep this locked away in a garage and run the other car your lusting after?
it would be such a shame to lose out on all your hard work mate for someone who probably wont cherish the car as much as you
aah well u dint say that :roll:
:lol:
well thats plan A :lol: but if i can get a price I'm happy with i may part. i have quite a lot of things to look into first, one would be storage. i dont have a garage :cry: i will try my best to keep it but everything is worth something. i haven't driven the car for about 4 days so i may change my mind when its back running on staurday and we will fall in love all over again!!! :lol:
id want 4k all day long for it and wouldnt take a penny less mate, please dont sell for cheaper it would be sacrilege.
or to a nooob that god no idea how to look after it lol
Tav: £3.5k if not 4k easily, if I had the money I'd give you that for it without a 2nd thought.
Edited by Ross
Tav: i heart ross long time
:lol: tav comes out the closet at last
i'll post some pics of how it looks right this minute cos those others are a little old.
I've just given it a quick rinse this afternoon. its undrivable at the moment as the charger is away getting checked. thats how anal i am. this weekend it will be back together and have the things mentioned checked and sorted.
The car is worth £3k of anyones money any day of the week.
I know how fussy you are with this car and how carefully you (or you make me) work on the car. It maybe a bit tatty exterior wise but even then its not a dog, with a good clean it comes up really really well. Mechanically its had so much done to it and thats the important part. The trim is awesome in it to. Has so many little details that make it worth the money.
If it was me, I'd struggle to take less than £3,750. At the end of the day with a lick of paint it could easily be the cleanest as-close-as-standard G40 out there. Finding ones that haven't been tampered with is only going to get harder so that should boost the value up a bit imo.
I think if you really want to sell it wait a bit for the market to pick up. At the moment people have less money to play with so not really the best time to sell imo.
Got to be worth 4k in my eyes, but as said try and get it garaged and keep it mate!
Wow! £4K easily! Its spot on! other than the lowering kit it looks like it just rolled out of a brochure!
see dan, i would quite happily pay up to 4k for it, BUT personally, i think you should keep it!
get it garaged, do the respray that you were considering.
never know, value of G40's might go mad like GT's atm...maybes its best hangin on, having some G smile fun at the weekend
