g40 chassis leg cracked question
hi I'm in the middle of doing an engine swap on my g40 well i say the middle but actually we only started at 3.45 today and we had the engine out by 6 lol. but after getting the engine out i thought i,d have a closer look at the chassis as i know this is a weak spot on the g40 and sure enough its cracked.and quite badly i think. does anyone have any pics of their cracked chassis so i can compare it too mine and does this mean the end for my g40 or can it be welded up? i have never had welding done on a car before or not this serious anyway. anyone remember how much it cost to get theirs weled up as i know a few people on hear have had it happen to them. basically any help you can give me on this would be great
steven
  • Views 1.7k
post up a pic - and people will tell you if its bad.
mine hadnt cracked but i welded mine up anyway with a good mig welder.
it is caused by the rear engine mount, as there is no front engine mount there is a lot of engine movement under acceleration and engine braking - and eventually the chassis leg moving up and down all the time makes it snap.
Rectified in 2 ways - gusset the joint around the base of the chassis leg - with a bit around the side of the leg just to make it welded all around.
add a front engine mount - but that is a custom job - and a bastard.
KiZ
here are some pics what you think
its kinda supposed to be like that - but not as big a gap.
its not a seam welded joint, iirc its spotted on from another part and bonded (glue)
so what i recommend is adding a few supporting welds seeing as you have it stripped this far.
seam it along the edges and add a gusset underneath were there is void in the panel.
it doesnt need to be a really big weld. 1inch of weld will hold 1 ton of strength - so dont go silly or you will end up weakening the rest of it.
KiZ
KiZ
u sure?? my bro kinda thought that too but it being a weak spot i thought it was cracked I'm not suprised they crack looking at them if thats how they are supposed to be
looks ok to me. listen to YP, hes knows his stuff.
